Fuel Gauge Problem
gt4WRC
The other day out driving i noticed after a good few miles, (using some good boost) the fuel gauge stopped moving at half a tank.... Then the fuel light came on a while after. So i put petrol in and the gauge went a little higher, but not much. (I guess this means that the fuse must be ok if the gauge moved at all)
So guys, any ideas what the problem might be??
sticky float inside the tank.??
How would you go about sorting that bt4 booster?? (big hammer?!) :rolleyes: cheers
