Celica 2.0l Engine Require
Neil1982
Hello all, im not sure if anybody has experienced this but a car i brought 2 months ago has just developeda little rattle from the engine and has now started to miss fire, when i took off the cover ontop of the engine i found that the four butterfly valves had turned into three. basicly the screws for one of the butterfly valves has dropped into the engine. So now i need a new engine........Anyone got one for sale its a st202 if that helps
  • 4 weeks later...
Agree with Glen,
Fensports are probably the best place to try. You could source one at a breakers for less cash, but you'll have no idea if it's a good one. Fensport won't send you the wrong one, won't send you a bad one, they'll supply what you need.
