Hilux Key
peterlomas
ive only got 1 key for my surf , anyone out there make themor knows where i can i made , another remote locking and alarm fob wold be good as well , thanks
Any reputable key cutting shop will be able to cut you some duplicates. As for the key fob, you will need to contact the manufacturers and possibly quote them the model number and the serial number from the system.if it's an after market system then you may be able to purchase one from them and they will supply the re-coding instructions
Hope this helps
Paul
Hope this helps
Paul
thanks paul , i,ll get some keys cut asap
