Oil Firation
peterlomas
ive been looking on the web for some kind of coking oil fitration system , can only find industrial type ones , anyone out there set their own up ? , been told i need to filter to 1 micron , ? anyone help ?
Peter.
Are you talking WVO or SVO, if it's WVO some of the guys on the Surf forum only run it through a pillow case, all depends on what it's been used to cook.
Peter.
i can get wvo from local chip shop for free , i did not imagine that using something as simple as a pillow case would work , got to try it , save a fortune , thanks
stick with wvo from chip fryers - into a pillow case is ok .
wvo used for fish,chicken and fatty foods contains fat globules which are not good for the surf and require various filters of 5 microns etc.
rig up a pump and use a big container have it pumping continuous to filter it overnight for you.
going try pillow case asap . done over 500 miles in my lux so far not missd a beat , well chuffed
great isnt it. :yahoo:
yeh really enjoying the different driving experience , was surprised that i get better mpg around town than on motorway . only 23 to the gallon at steady 65mph , ah well cost of driving a big car i suppose. still chuffed !!!!!!!!!!
i managed 25 litres in a pillow case , now its just clogged up with fat.
so another 1 is needed.Its a messy carry on like !!!
crack i hear is, leave it in a 45 g drum for a week or so to settle and skim off the top what you need gently so you dont stir it up and its as clear as a bell.
i used 2 pair of old nylon tights today , pretty fine mesh , filtered quickly enough too. Only microscopic bits passed through.Left with a thin layer ontop like scum after a bath , caught that out with an old small fish net . i then bottled 30 litres off into old 3 ltr bottles to settle . gonna give it a week and start using it.
Well i added 18 litres of the brown liquid added £25 of derv , and just done 385 km towing my caravan to scotland and a bit of sight seeing in between, without a bit of bother.Will be checking my fuel filter soon to see just how clogged it has become .
cheap as chips , didnt smell as bad as the makro cooking oil either.
