Dripping Water
br0ke
Our new Verso is parked in the drive every night. There is a slight incline with the front higher then the rear.
Every morning after it rains (which is pretty much all the time) when any of the doors are opened water drips out the bottom. I presume it is water running down the window and into the door skin and I also presume it is meant to do this as all the doors do it but surely this cannot be right.
Has anyone else noticed this before and am I right to be concerned about it?
This is normal, it is probably coming from around the door shut seals and pour off when opening the doors.
Also the doors have drain holes in the bottom, unless the water is inside the car i wouldnt be too bothered.
Mart
