Aircon Problem
navygm
anyone can help pls? I've got a starlet 1.5d and when I switch on the Ac the led of it keeps blinking and ac doesn't switch on. any ideas?
a blinking LED usually means that there isn't enough coolant pressure in the aircon system.
This seeps out over time, especially if it's not used on a regular basis. Plenty of places do a regas service, or if you want to top it up yourself you can get cans of pressurised coolant from Halfords etc.
If you take it somewhere to get regassed though, they can check the system out for leaks etc while they're on with it !
cheers thanks very much
will check re this problem at a local aircon mechanic garage and we see..
