Engine Management Fault - Self Diagnose?
chrisb1976
Hi, My Engine Management fault light has come on. I've managed to fix it by disconnecting the Battery for a short while BUT it's came back on after about 2weeks. I've done the Battery thing again which has fixed it but I guess it will probably come back on sometime soon.
I searched on here and found that you can buy a tongle thing to self diagnose these problems (www.scantool.net) which works out cheaper than getting toyota to diagnose it for you!
Has anyone used one of these things? and are they any good?
If they do work will Toyota be ar5ey if I tell them what the problem is that they need to fix?
Thanks in advance,
Chris.
