Bluetooth Addressbook - Manual Entry
jontracey
Seems my mobile phone (blackberry) will make and receive calls no problems, however it wont transfer its address book. So is there a way to manually create a small address book. Every-time I press the address book button it asks for a transfer, but I cant seem to figure out how to enter a few numbers
Any tips gratefully received
Jon
Jon
bluetooth transfers are always a bit of a challenge! no matter the phone!
step 1 pair the p[hone with the car via the phone settings screen and set the phone to auto-accept the prius.
then (there may be changes for you phones menu system) go into address book on phone and select the transfer by bluetooth option while on the prius select phonebook/import addresses and once both these are done it should transfer.
works ok with Samsung D900 and nokia 6133.
