Presure Washer
vmail
I got a presure washer yesterday and washed my car today
it leaks a bit, is that normal or will I need to take it back?
The car, or the pressure washer?
Where does it leak from? Are the hoses connected properly using correct washers etc?
Mine doesn't leak, so yes I think you probably do need to take it back?
all hoses are correct and theres no leaks from the hoses.
it leak from inside the machine
Take it back. It can only get worse...
ok, will do in the morning
I do have another leaking problem
the outside tap leaks when there is something attached to it, do I need to change the whole tap or will it be something like an o ring?
When something is attached to it? And it's turned on I imagine?
It's water leaking back past one of the seals; you could probably replace them, but a new tap costs a few quid from B&Q or a plumbers merchant. You can probably just turn the water off at the stop *****, unscrew the old one off its mounting bracket and screw the new one in. Only problem is that the new tap may not be vertical when it's screwed in, but so long as it points vaguely downwards it'll be fine.
HTH
^^^ Lols at profanity checker
Pressure washers are good for drawing things on dirty patios.
Thats all I know.
And shooting women with white tops on passing the end of your drive.
cool, Ill give that a go
fixed the tap, just had to tighten the nut
