Major Grounding/bottoming Out Problems
sphinktar1988
Well i have an sr and i took the TTE springs off and replaced them with
Koni 40mm springs
was fine at first dropped the car just about enough
had them on almost a year now and never had any trouble with ground clearance
over the last month the cars been catching on speed bumps when i have a few people in
but today i had only myself in the car and its bottomed out like 3 times on speed bumps and once on a normal bump going in to a car park :|
im really starting to worry as its a large thud just after the front wheels when it happens
are my shocks going? or spring nackered? or are they just going to be like this?
is there any reason why this would happen? cause ive never heard of springs goin on the yaris
cheers
Mine does this on the front too but i'm slammed. Its such an awful noise but i just try to avoid speed bumps etc. If you check underneath the car, i can see no damage so it cant be that bad :P I also find something underneath the drivers side scrapes when i half mount a curb parking outside my girlfriends. Hopefully its not the newish sump i had fitted :P
Koni 40mm springs
cheers
Hi, I had a similar problem on a car with STANDARD springs!
Started bottoming out over bumps (everywhere where I live) I got some Koni adjustable shocks from motorsportworld and had them fitted. Has been fine since.
I think the shocks that were standard are cheap rubbish designed to last for the warranty! My car had done less then 30k :angry:
thats wat my mate was talkin about
he said ur shocks mite be nackered
if they are im just guna get coilovers :D
cause the koni shocks n spring on eBay are like £350
may aswell pay the extra n ave the coil overs :)
guna be fun puttin this back to standard wen i sell it :|
shocks could be on their way out, and your springs have probably sagged over the time they have been on the car, which is why it's catching.
The above is probably the reason I reckon. I remember you saying that your car has done quite a few miles over it's time and depending on the life of the shocks, they could just be worn. If you've never changed them yourself, they could be as old as the car is.
Your shocks and nackered because you have had lowering springs on standard shocks.
The koni shock and spring set up will be a better buy for a handling but if you really want it super lower where you will catch anything anyway go for the coilovers.
