Lexus Sc430
DazH
Well I was sitting in traffic on the Tyne Bridge comin outta Newcastle tonight on way home and I let an SC430 out into the flow of traffic. First time I've seen one close up and what a beast of a car it is :drool:
Don't think that he thanked me but if you can afford a 50k plus car I don't suppose you have to :lol:
he didn't thank you?
THE PURE IGNORANCE OF IT, WHAT DOES IT TAKES ?!
a smile, a raised finger (ahem), a wave, a thumbs up, a wink (hello ;)), a tannoy type system mounted into your car that allows you to say 'THANKYOU' over a loudspeaker :o
any form of recognition will do!!!!!!!
GRRRR. :angry:
he probably waved but you were too busy looking at his car :D
Overtook on on the duel carrage way to crawley on sunday :P He wasnt playing as i wasnt even going very fast when i overtook him :(
What is the performance figures of these then?
Performance & Fuel Consumption
Maximum Speed: 155 mph
Acceleration 0-62 mph(0-100 km/h): 6.4 sec
Drag coefficient: 0.29 Cd
Fuel Consumption
Urban: 16.4 mpg
Extra-urban: 31.4 mpg
Combined: 23.5 mpg
CO2 emissions: 287 g/km
Compression Ratio: 10.5:1
Dimensions & Weight
Dimensions
Length: 4515 mm
Width: 1825 mm
Height: 1370 mm
Wheel base: 2620 mm
Fuel tank capacity: 75
Luggage compartment capacity: 368 litres (with top up)
135 litres (with top down)
Gross vehicle weight
Front: 1005 kg
Rear: 1105 kg
Total: 2110 kg
Maximum permissible axle capacity
Front: 1030 kg
Rear: 1140 kg
Kerb weight
Kerb Minimum: 1740 kg
Kerb Maximum: 1790 kg
Wheels and tyres
Wheel size: 8JJ x 18 in
Tyre size: 245/40ZR18
Chassis & Body
Extensive anti-corrosion protection
Super-high quality finish featuring multi-layer paint treatment
Exterior
18 inch alloy wheels with locking wheel nuts
High intensity discharge wave-reflector headlamps, with auto on/off washers and automatic levelling Front fog lamps
Electrically-adjustable, foldable, heated exterior wing mirrors with auto tilt down
Key-integrated comprehensive vehicle security system including alarm, immobiliser and double locking
Engine & Transmission
VVT-i - Variable Valve Timing - intelligent (electronically controlled)
ETCS-i Electronic Throttle Control System - intelligent: advanced computerised engine management system
5-speed automatic Electronically Controlled Transmission (ECT-i) with intelligent computer control
AI shift system
Dual stainless steel exhaust system with catalytic converter
Cylinders/valves: V8/32
Capacity: 4293 cc
Compression ratio: 10.5:1
Stroke/Bore: 91.0 x 82.5 mm
Maximum output: 282 bhp (210 kW) @ 5600 rpm
Maximum torque: 309 lb/ft (419 Nm) @ 3500 rpm
Suspension, Braking & Safety Systems
Suspension
Front: Double wishbone
Rear: Double wishbone
Brakes
Front: Ventilated disc
Rear: Solid disc
Safety
Driver and front passenger airbags
Front seats side airbag system
Front seat belts with pre-tensioners and force limiters
Vehicle Stability Control (VSC)
Traction Control System (TRC)
Electronic Brake force Distribution (EBD)
Brake Assist (BAS)
Anti-lock Braking System (ABS)
Auto levelling headlamps
Foot-operated parking brake
Impact absorbing structure
Interior
Climate-control air conditioning with separate driver/passenger temperature controls and automatic air recirculation system
Speed-sensitive power-assisted steering
Electrically multi-adjustable steering wheel position
Cruise control
Electrically multi-adjustable heated front seats with lumbar support and memory function
Electric windows with anti-jam protection and one-touch auto up/down feature on drivers side
Leather upholstery
Tyre pressure monitoring system
Photochromic rear view mirrors
3-spoke leather-finished steering wheel
DVD-based touch-screen Lexus Navigator System
Audio
Mark Levinson® 9-speaker stereo hi-fi system with 3-wave-band RDS radio with 18 pre-set channels and Dolby cassette
In-dash single slot 6 disc CD autochanger
Automatic sound leveliser adjusts volume to ambient noise
Electric aerial
Steering wheel mounted audio controls
Click Here For More On The SC430
SC430 -what a total pile of :censor: I'd have a PROPER soarer over that any day!!!!!!!!
I can't beleive they soiled the good soarer name with that overweight mutant SLK/audiTT monstrosity.
yet ANOTHER example that the new toyotas have lost it. :crybaby:
The house over the road from where I used to live had one of these, never even realised it was anything special. Personally I think it looks like a Hyundai coupe or something like that. I think there are nicer cars out there and for a lot less money.
The car I really want to play with right now is a Mazda RX-8 (I'd be happy to settle for an RX-7 failing that). It may not be Toyota, but I just like the idea of outperforming 3litre cars with a piddly 1.3 litre rotary :P . As I said, failing that a twin turbo RX7 :drool: .
its the car that was in terminator3 (i hope)
yup, that was the one
its funny as well cause i hardly see it and when i do, i saw 2 of them yesterday while coming home...... <_<
I persoanlly think toyota have lost it with they new "sports cars" (not trying to offend anyone ;))
my next car will either be a later spec soarer TT (will be my 3rd lmao -I like em ok?) or a late spec RX-7.. gonna keep the supra as a classic :thumbsup: Adi reckons theres probably less then 10 like it in the uk :blink:
sorry but the mk4 supra does not do it for me *sheild self again incomming rotten fruit* and the skyline is too bland...
I could however happilly see myself in an Aristo V300 :thumbsup:
Did I mention I've driven a SC430....
A very nice car... more of a Monte Carlo crusier than a sports car... that said, the 4.3 V8 certainly has some go...
If i could afford one, and make do with the tiny rear seats, I'd have one..
how much you looking to spend on a soarer mate?
would a manual suit you sir?
depends what I see.... I'm not ready to get one yet.. probably by the summer...
I DO want manual, but an auto is easily converted, so its not a huge HUGE issue. I'd probably ideall got for a 94 GT-TL spec.. (as late as ***** without the silly extra grille).
I'm not after a silver one tho mate.. had a silver soarer for nearly 2 years.. after a black one. :D
as for price.. depends on the car... my first soarer was bought about 4 years ago.. was a shade under 10 grand!!! (tho it was known on LSOV as a "tidy one" my second soarer was a higher specced car, but bought as bankrupt stock from auction.. -£2800... sold it for a fiver under 7 grand :)
probably look to spend 6-8 fora nice one... if its the spec I want....
Amen brother!! :lol:
I would love a big monster skyline or supra.... bah
suit youself :P
I'm not a fan of the new supra (if I was I'd have got one), not a great fan of the skyline (likewise).. and grew out of escort cossies when I was 15 :lol:
I do like the MR2 turbos, and the celica GT-4s.. but look at the replacements.. is there anything "new" that compares to the old ones? nope. same with soarer.... same with the upcomming mk5 supra...
Clearly there are only a couple of us on here that agree :) it doesn't bother me now... I don;t buy new cars... but come a few years down the line we will be getting cars that are more modern then the ones we have got... out the current line up..... I can see me changing brand.
Do any toyota head office/officals frequent this site?
I've got a Lexus Sc430 and also a new Yaris D4D spirit and they're both great fun.
You're right that the SC is a (summer) boulevard cruiser....which is why its tucked away in the garage for now :P .
Mind you given the choice for a short trip I take the Yaris every time cause its nippy, its got perky handling,its reliable and has great economy. :thumbsup: .
Wait till the summer though!!! B)
Cheers,
Buzzuk
I love the new SC430... suits me sweet!
