Headlight Adjustment
AidanKildare
Can anyone tell me what the headlamp adjusters look like on the facelifted E12? I've found two likely candidates - one's a nut at the centre of the headlamp rear (below an electrical connection) and one's in the corner of the headlamp unit, beside the wing. Are these the adjusters and am I right in assuming that the centre one is for up/down adjustment with the corner ones being for left/right adjustment?
Any help/suggestions would be much appreciated.
Not sure which one is which again. You could try either with your lights on and then you should be able to notice the beam move in the direction.
I think the ones in the corners move the lights up and down.
