Ts Key?
DJNS
Hello all,
My key has just snapped clean out of the plastic housing, i think i've found an alternative route instead of going down to the dealers and forking out £120
http://www.3dgroupuk.com/index.php?categoryID=33
I'm not too sure which key is right out of the three two button ones, so can anyone tell me if the TS key is manufactured by Denso or Tokai Rika.
I know the info should be on the back of the key but the sticker wore off a long time ago, anyone still got the sticker thing on their key??
Can anyone shed any light on this...
mine says Tokai Rika on the back for the facelift t-sport
Thank you guys, i've just ran the part number from that tokai rika key through my epc, it comes under a gen 7 celica key. perhaps same key interms of blade length and width?
Probably but don't quote me on that. My mum has a MR2 mk3 and the keys are almost identical! :thumbsup:
I have had two of these now as i seem to be able to snap them regularly.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:B:EOIBSA:UK:11
The replacement key is a denso - dont know whether my original was or not as the sticker had come off, Mines a P2 by the way.
I've got one of these, it's not as wide as my key blade, its slightly shorter too. Did you get this denso replacment key working for you?
Yeah, I use it as my main key. I just got it cut at a random locksmiths from my old key and swapped my transponder between the shells. The blade was identical in size to my original.
I find it strange that they would use two slightly different blade sizes but you never know...
i've contacted a few of the sellers regarding the blanks they sell, they are 4.5 cm long n 0.7 cm in width...where as myne is 5 cm and 1 cm wide...can anyone tell me what it says on that sticker thingy on your keys? all the ones on eBay are CE0123..
i've contacted a few of the sellers regarding the blanks they sell, they are 4.5 cm long n 0.7 cm in width...where as myne is 5 cm and 1 cm wide...can anyone tell me what it says on that sticker thingy on your keys? all the ones on ebay are CE0123..
CE0122 on mine. :)
