id like to know where to look and how much it would cost to buy a 5e-fhe and all the parts to put into my starlet, with a 4e engine.
how high does the 5e-fhe rev?
will the gearbox and clutch go straght in?.
as much as id like, i deffinatly can afford the turbo.
is anyone sellin a 5e-fhe :help:
some one must have a slight clue where i can find one of these engines :help::help::help::help::help::help::help::help:
5E-FHE was only used in Sera and Cynos (Japanese Paseo). Quite rare. I need two engines myself.
Andrew
can anyone put me on contact with a person who could sorce a 5e-fhe engine out of a cynos or sera
where would be the best place to look for this engine, im gaggin to find one :help::help:
can u tel me what all the differences r between the 5E-FE and the 5EFHE engines??
Just out of curiousity I bashed "5e-fhe" into Google: all the sites are in Japanese, Korean & Russian, so good luck! One site mentions Japanese market Tercels & Corollas.
Yannick
Topics merged. :thumbsup:
Buy a Sera or Cynos. They'll have one.
I've got a Sera arriving for parts tomorrow. Engine fine. However, someone is already in line for the engine.
I also know of another Sera with engine failure.
Earlier in the year I had three spare engines... Subject to supply and demand...
IF i find one of these engines how much should i be lookin to pay for the engine, loom and ecu??
Depends what condition the engine is in. Between £ 300 and £ 600 would be fair.
They're different automatic to manual as well. You'll also need to make sure that you get the coil and ignitor, some of the bulkhead pressure sensors.
You may need to get your flywheel redrilled (and balanced afterwards) because the 5E apparently has a different flywheel bolting arrangement to the 4E.
For ease of install I would suggest buying the 5E-FHE engine together with flywheel, clutch and manual gearbox and then you know you won't have any problems.
Andrew
u said in an recent post that u had all of these ancilerys for sale. do u have gearboxes ecus and the like for sale??
I've got sevral gearboxes, clutches and flywheels, lots of ECUs - but a dire shortage of engines.
Andrew - do you have any downpipes spare?
or know of anyone who makes them up?
J
Hey Andrew, you have any 4efte ECU's and harnesses sitting around I could buy off of you?
