Hello guys,
I am about to carry out an intermediate service on my wifes 2001 avensis verso 2..0 D4D. I cannot find my owners manual and am unsure how much oil to put in with a filter change. In my mind is the figure of 6 litres but this seems a lot. I drive an audi A4 with a 1.9 diesel and it only takes 3.4 litres so I am confused. I am also planning to use Millers XFE 10w40 as this has proven to be excellent in previous cars. Mileage is 67000.
Any info gratefully accepted.
All the best
Dougie :unsure:
6.4 litres including a filter, I would use 5w 30 for better fuel economy, rather than 10/40. Cheers Kingo :thumbsup:
I've got the 2.0 litre D4D in my 2006 Corolla SR and that needs 5.9 litres including filter.
You should always "Under fill" by a little, start the car, check for leaks, stop it, check oil filter and sump plug for tightness, then re-check the level. I have re-checked the spec sheet, it does say 6.4 INC oil filter change
Kingo :thumbsup:
Just wondering if the engines are the same then. Is the Verso the 2.2 litre engine perhaps?
Kingo :thumbsup:
Guys,
Just located the owners manual after a major search (just moved house) and it states 5.9l. Thanks for the replies.
Dougie
