Dump Or Blow
yellgt4
I HAD A SARD R2D2 ON MINE - eBay from japan, cost about 78 quid all in . sounded well loud
is there any difference between a blow off valve and a dump valve. apart from the sound.
A blow off valve and a dump valve are the same thing :rolleyes: .
Not sure what they are like on a GT4 but HKS SSQ is a good quality bov.
yep R2D2 are awsome got one on the rolla, and yes i too can confirm they are loud
Interesting, maybe I shall have a look. I have a DV24 and was told it was too weak for the car by an expert. It dumps all the time! (not literally, but almost) Having no previous turbo experience I don't know whether this is right. I called Bailey with the intent of a stiffer spring as advised but they assure me it is fine as it is.
Any thoughts on spring weakness?
R2D2 sounds good just from the name.
i have a dv34 and mine does dump all the time. as far as i can work out it is because it is a single piston valve, same as your dv24. i got told that the gt4 needs a double piston valve.
but if you get anywhere with the stronger spring theory let me know. cheers mate and good luck
