Brake Fluids
Pompey Gaz
EDIT: found its dot 3
but the owners manual said i can use it to fill the clutch reservoir too, is this true?
Might have been dot 3 back in the old days, we use 5.1 now, like everything else in the world, specs get enhanced over the years, 5.1 is a better spec than dot 3, You can use it in the clutch cylinder too. cheers, Kingo :thumbsup:
