Rubber Around The Lights?
lobonMR2
Hey folks,
About to get a GT4 in the next couple of days, when i was up seeing the one im after though, the rubber around the lights at the front seems to be, erm loose is the best way to describe. The guy says thats an issue wit all celica's and some ppl just take it off, anyone got ideas for sorting? or should i just jab em out too? lol
Ta,
Gary
Hey folks,
Ta,
Gary
The rubber surrounds are only held on by about 4 small metal clips, over time the rubber "edge" that the clips holds onto splits off the surround and hence the clip has nothing to hold onto and the surround becomes loose.
You can either as you say remove it completely or just stick it to the light unit with some silcon sealant or similar :thumbsup:
As said sealant does the trick. I had way too much free time so removed the lights (and the bumper) to seal them back up properly.
mine are the same my fella is sick of clipping them back on. think i only have one clip left on one side and the other is touch wood stayin on by magic lol
