Delimiter
gt4.5
I imagine you mean where is the limiter ??. Well the limiter is a function of the ECU. To delimit you have several options, you can get a unit that splices into the speedo that converts the speedo from kph to mph and tricks the ECU (about £60) or you can get a piggy back chip to run with the ECU (£ ????)
