Strange Sound In My Corolla
ArtCYPRUS
Hello
It's my first time i write to the forum
I bought a second hand,2003 Corolla 4 door saloon 1600cc vvt-i from Singapore
When i turn the key to the ignition position , there is a strange sound coming from somewhere behind the tachometer
The sounds continues even when i start the car.
Does anyone knows what it is??
Thanks in advance!
:D
mine clicks a little (not loud but can hear it) when i put the key in i think its the immobiliser turning off or summit ati theft.
The sound came again!!!!! HELP
I will try to explain it,
When i turn the key to the start position and all the lights turn on, a sound starts coming from somewhere behind the tahometer
(its a stock one).The sound continues even after i start the engine.
Anyone??
Anyone??
is it a clicking sound??
Yes its like a click, or a tick you can say,
i believe it should be some electrical sensor or something, because the sound starts from the time i turn the key, before i start the cat
every car has a SIM in behind the steering wheel, its like an ECU for the interior lighting and speedo clocks. when u turn de key it sends a signal straight to the SIM to activate the clocks and lights, is everything working properly on de tacho and speedo ect..?? cud just be a simple problem in behind it.
