Obd Ii Codes In Gen 4 Camry
I'm wondering what ports do I run the jumper wire to on the diagnostic connector to get the ECM to read the codes back through the check engine light? Any advice, or maybe a diagram or two would be greatly appreciated! Thanks.
here's another link with some info and diagram.
http://autorepair.about.com/library/ts/obd...bl-dtcs-48a.htm
Both this link and the one mentioned above say the diagnositc plug under the hood is located on the drivers side, but on my 93 Camry V6, the plug was on the pasenger side, near the fire wall.
I also noticed the list of fail codes was somewhat incomplete on these sites but my haynes manual had a more complete list.
Retrieving the fail codes was super easy, just did it today. Just jumped the 2 pins with a short wire, turn the ignition key fully on (not starting engine) and counted blinks
