My Nose Is Getting Dull.
JappyBeast
My MR2 has started to dull on the nose section.. I use Auto Glym Resin Polish but it doesnt seem to do the job, well it looks good at the time but doesnt keep a shine, especially on the flat part. What can I do?
I also use Auto Glym shampoo when I wash. The rest of the car looks ok tho.
I find that if the bubbles get in my eyes it stings.................so I use Lynx shower gel ;) :P :lol:
polish it up with a bit of g3 best to go to a body shop and ask them to machine polish the front end for u should bring it up a treat for while
t-cut it then polish, when i got my car it was so faded.
thats all i did and it took the years off :)
Jappy,
I've tried a lot of different shampoos and found the best combination to keep a good shine (after you get it back)
is turtle wax shampoo/ wax combo, mixed in with a good few squirts of fairy liquid. Makes it shine every time :D
Dave.
Why not re-paint it something other than purple??!! :lol:
thats a brill idea
daniella westbrook springs to mind :P :D :D
you could try the blue peter approach.... sticky back plastic watch it shine..
Note sure what make of paint it was that you got on your car Jappy, In my experience this happens with cheaper paints after a while, and you also got the plastic thing with the nose cone, some paint can look a shade out between metal and plastic. Dont know why and everyone says it should not happen, but it does, and it can get worse with age. There is also the constant barrage of rubbish that is hitting your nose cone first.
Anyway, I would give it a hand T-cut (original) and then keep the nose waxed, it will help retain the shine longer, once you cut it once regular waxing will keep it cleaner.
Use what you like but I use a simple wax that I buy for £30 per gallon. My brother uses auto glym and Meguires and when our cars are both cleaned you would not know the difference.
The nose and metal are an exact match.
The paint guy says certain colours (red, yellow) lose they shine eventually because they dont use lead in the paint anymore.
What wax do I need to use?
