Ecu Error Codes
nathanfreke
My girlfriend has an 02 yaris T sport and the ECU light has recently come on. Im an MR2 man and know that you can check the ecu error codes via bridging ports in the diagnostic box, is this something you can do with the yaris?
If so, tell me how!!
Thanks,
Nathan
Thanks,
Nathan
Don't think it is possible with the OBD3 port on newer toyota's
You will need a code reader.
I believe it is possible on T-Sports, but its so much easier to use a reader. There's a list of codes and stuff here:- http://tinyurl.com/2zp9tb
If you do a general search on here you should find posts about the "diagnostic paperclip".
A
