Stereo Removal
mogie
there is probably a removal guide on techdoc that someone can post up but i dont know how to do that sorry.
If you remove the 2 silver/grey panels either side of the stereo (give them a good pull they are just clipped in)
You will then be able to see 4 10mm bolts holding the stereo into the dash. Possibly a couple of screws holding the heater controls too.
Just dont pull anything too hard and make sure all fixings are removed. Pretty easy to do just take your time.
Mart
Be very carefull when taking the left side off, be sure to start from the top as there is a metal clip at the bottom which will damage your inner dash, i have took mine out today but luckily i removed the glove box first and looked behind with a torch
