Help Please!
Iain-d
After finding that my fuel tank was busted, and rear brakes were shot, repaired both, took car off ramp to find that it has anothar problem.
now everytime the turbo starts to spin the car backfires, and will not go above 4k
have checked the fcd, but all seams fine
any ideas????.
thanks in advance
have you checked the ECU for fault codes? what sort of mod's has your car got?
yes have checked the car for fault codes, they re as follows.
22 which appears to be the temperature sender
34 ????
35 ????
the last two don't appear to have any info
as for mods, think its runnning bigger turbo off st205 with blitz twin solenoid controller.
appears that the fault is getting worse now car will only run with the ecu light illuminated, as soon as the light goes out can't get any acceleration at all.
still showing fault code 22 after resetting ecu.
checked fuel pressure, lambda sensor and ht leads but all seam to be fine.
