K&n Typhoon Kit
CTS-Beast
yeah it will still lock with key. u'll have to lock passengers door aswell
ok got the Battery off and connected it back i started the car and i reved it there is a slight improvment on the roar but i have not yet took it for a drive another thing i have noticed is when i swich the engine off there a slight noise cumin from the engine
Ahh that sounds like the same noise i was asking about when i first got it fitted. I never got an answer from anybody which is suprising as so many had the kit fitted before i did. I was pretty worried, it does it everytime you kill the ignition. I have put this down to the the amount of extra air being constantly sucked in, even when idle. When you kill the ignition, it still sucks air for about 1-2seconds, more of a sucking/whoosh/rumbling/gurgling sound.
Had the sound ever since i had the kit fitted and no problems. Does get slightly annying but i have got used to the noise now.
BTW: Did you fit the additonal air pipe? Or you have left it just sucking air from where the old airbox was?
I added another air tube that is mounted beneath the cars front, just below the spoiler, not visible at all. So i have two pipes for air.
Have fun with it, sounds like its all ready for a good driving.
On an unrelated note: has anyone noticed the car does not want to start on the first crank when the car is warm? Is the heat from the engine being recirculated into the air filter when stationary? Usually starts on the 2-3rd crank when warm, but when cold it starts on first crank.
Armz.
Armz.
hi m8 i never fitted mine i got a garage guy to fit mine will it roar now
Armz.
Garage fitted mine too. I stood and watched them as they fitted it and also put it on a lifting device to fit the pipe underneath and snake it thru the engine bay up to where the K&Ni is.
Armz.
i think someone has fitted it wrong. my is really quite loud.
when i rev it its load but i have not drove it since i have put the Battery bk on
LOL!, what are you waiting for? Take it for a drive, go get 'em tiger! :thumbsup::lol:
Should scare the whole neighbourhood now.
Armz.
i have a k&n on my compressor which was on my previous t-sport yours will roar just set of an foot to floor you,ll only hear it if you are accelerating quick enough your hearing the air rushing through, :driving: if you only drive steady its not passing through quick enough the make a sound
what a roar man it sounds bad
LOL! were you driving with both windows down? If not try that aswell. It'll sound damn loud.
My favourite is passing through tunnels the longer the better, i wind down both front windows fully and floor it. What a noise!
Armz.
Armz.
but i can still hear the roar when the windows are up
Armz.
LOL, ofcourse you can, but its soooo much louder with the windows down. If there are any tunnels near you try what i suggested. The sound characteristics of tunnel amplifies the sound so much more, sounds like 5 t-sports hitting lift all at once!. :lol:
Fitted my K&N, had the Battery disconnected whilst doing it,
when finished fitting reconnected started up drove it straight away
no lights on :) and roared :D
well happy and roaring :D
