Seat Belt Warning Chirps....
Nightstalker
Hello you fine Rav4 People....(yes I know I'm slacking with posting pics....they will follow after me hols! ;) )
Anywho...
I am sure I've seen this posted before but cant find it... :unsure:
Anyone there know (anchorman/parts-king) how to turn the annoying beeping noise off on the seat belt warning dubry furkin on me new Rav 4 3? :huh:
rgds
Rop
B)
Rob, i could not find it either, but it is on here somewhere.
If I remember its a sequence of turning ignition on and off while pressing odometer ?
sure Anchorman will help you later with reply.
Dave ;)
BLINDINGLY OBVIOUS - YOU TURN THE music UP AND WEAR A THICK, HEAVY KNIT BALACLAVA....... OR JUST SING IN TUNE WI THE BEEP?? :lol: :lol: :lol:
I've never tried this guys, I just put my seatbelt on!
http://toyotaownersclub.com/forums/index.p...&hl=disable
I don't know if it's totally disabled or defaults to on when you next turn on the ignition.
Let me know.
Cheers
That one did not work....
however I think another one did...will check it out later today when I go home...I do wear my belt, its just when things are on passenger seat - other than the wife...Also what happened the other day, I got out me Rav and left the engine running and the chirpin kicked off and drove the other half potty... so will see if it works...
The steps are pretty much the same as in the link you posted anchorman,
switch ignition on
set speedometer display to ODO
switch ignition off
Hold down ODO button
switch ignition on and wait 20 sec
Whilst still holidng down ODO button put seatbelt on
Let go ODO button go and that seems to do it.....I think, will test it out later today....
The seatbelt buzzer is on the customer parameter list so your dealer should be able to do it.
Here is a method off RAV4 World (slight variation with foot off the brake and looking for the instrument display);
1. turn the key to the ON position, foot off the brake
2. cycle the odometer with the trip reset button until the ODO is displayed (not trip A or B)
3. turn the ignition to the LOCK (OFF) position
4. unbuckle the driver's seatbelt if it was buckled.
5. turn the key to the ON position. when the dash lights have come on, press and hold the trip reset button and count a slow 12 seconds. (editor's note, hold it more like 30 sec)
6. while still holding the trip reset button, buckle the driver's side seatbelt.
7. the odometer display should read "b ON" or "b OFF". toggle the beep OFF with the trip reset.
8. the process should be completed when you unbuckle or turn the key off.
If that doesn't work this one will! The fella has disconnected the actual buzzer from the instrument cluster!
http://rav4world.com/forums/viewtopic.php?...light=seat+belt
Remember you don't have to fully disable it, a piece of masking tape over the top will make it very quiet.
Don't worry about getting the instrument cluster out, it is very easy.
Cheers
Cheers
Na that didnt work either....
However it does look familiar to me...think I used that tip to disable the sound on my avensis....
Called MR T but they did not have a clue and suggested I call back in the morning and speak to a techie...
Will keep yous posted.
Rob
B)
According to the workshop manual it can definitely be customised with their diagnostic module. This is cut and pasted directly from it;
HINT:
The following item can be customized.
NOTICE:
When the customer requests a change in a function, first make sure that the function can be customized.
Record the current settings before customizing.
When troubleshooting a function, first make sure that the function is set to the default setting.
Combination meter Display (Item)
Default
Function
Setting
Seat Belt Warning
D/P ON
Seat belt warning buzzer ON / OFF setting
D/P ON: Driver and passenger buzzer ON
D ON: Driver buzzer ON
P ON: Passenger buzzer ON
D/P OFF: Driver and passenger buzzer OFF
Anywho...
rgds
Rop
B)
reply
it drives me mad but the other day i ignored it and after a few mins it stopped making the noise itself!
