Bluetooth And Stereo Muting
seadoogsx
Recently bought the Verso T3 with the bluetooth SWC. All working well, except when the call comes in or make a call it turns off the Speakers in the front, but only turns down the Speakers in the rear. Doesnt turn them down that much so its very distracting. Is there anyway of changing this setting to mute all Speakers or turn the volume down further automatically? I end up having to turn down the radio manually.
Any thoughts?
Paul
Hi
I have the bluetooth SWC in my Verso TR - it swtiches off the radio completely - all Speakers. You should be able to find your wiring manual here:
http://techdoc.toyota-europe.com/aim_Searc...4539&admin=
Search for SWC in accessories - it brings up a load of manuals - one of them should apply to your setup - I couldn't link directly for some reason but I found mine.
Cheers
Gidon
Hi
I have the Bluetooth SWC in my Verso TR - it swtiches off the radio completely - all speakers. You should be able to find your wiring manual here:
Cheers
Gidon
Thanks for this, i didnt fit it so should I just go back to the dealer? Im not very techy when it comes to wiring or is it just a menu option in the bluetooth kit or stero?
Sorry I'm not techy either - personally I would go back to the dealer. I can't recall an option to mute the Speakers but you could double check the manual.
I find it an excellent accessory - after changing the language to UK English - it has worked perfectly.
Cheers
Gidon
