Squeaks And Squeals
SilverT4
My almost 4 year old Prius has started to make squeaking and squealing noises from the front end.
I'm guess I'm gonna have to take it in, but heres what I'm gonna have to tell my service dept.
Difficult to say from which side. If you wind the nearside window down you hear it from that side and vice versa with the offside.
Doesn't happen in the morning when I go to work (maybe as its cooler temperature)
Happens a lot when I drive home from work
Is worse with two people in the front
Its better when there is someone sat in the back.
Sometimes just getting out of the stationary car make sit squeak - sounds like a suspension problem
Only happens at low speeds
Sometimes when braking
Sometimes when not braking
Any ideas what it might be?
