Rav4 Power Steering Intermittent Failure
Browny
There have been similar failures of electric power steering on other Toyota models and there has been a recall. If the fault light is on - it should be possible to extract the fault code - this will be in the form C---- and this will give a clue as to where to investigate further - C1554 is often the code for steering ECU failure . The issue on other Toyotas relates to the steering ECU - there isn't a history of this on the Rav4 so it might be a case of watch this space. Where other systems fail at the same time as the steering, then loose / wet / dirty connections are to be suspected.
Thank you everyone for your wonderful replies they are all greatly appreciated as frustration levels quite high.
Kind regards,
Kerry
Kind regards,
Kerry
Kerry
Any progress on your problems?
Bryan
Hi Bryan,
Car still at the auto electricians trying to fix the issue. He has been talking to a number of Toyota service centres who are also unsure of the issue. He is checking connections and looking at replacing ECU but needle in a haystack with the amount of wiring connections. I am forwarding on all helpful suggestions given to me on this forum to him. Will let you know the outcome. Thanks again Kerry
  • 6 years later...
Hi
4hrs from home nearly got wiped out by a truck when the same lights came on in my 07 tab and it lost all power and p/s.
Has anyone gotten to the bottom of this issue? As my car is spending Xmas at Toyota as they’re not sure what to do.
