Right Finally After A Year A Topic About Fixing My Flat Spot
sphinktar1988
Right Guna try bullet point this as theres lots of info to fit in and i dont wanna bore you with a massive amount of text
if you read on you will understand why i am scared to put a new cat converter in before my MOT as i worry it will happen again
1.3 2000 X reg sr
the problems started when i had a garage take my centre pipe out of the standard exhaust system
was fine at first but then a 2 or 3 month later my engine management light came on
my car then developed a small flat spot which has got worse over time
then it failed its MOT test on emissions he said they were thru the roof
trying too fix the problem i had the cat taken out and looked at, it was totally melted and useless it got binned as the exhaust centre said it had been over fueled
ive since replaced the whole exhaust system with a powerflow system and is currently decat'd
the flat stop has never changed no matter what has been changed on the car
the flat spot is only when first touching the accelerator and the car feels very sluggish untill in high revs
the only way to pull away is to tap the pedal till the revs build up
now for my MOT i have to put a cat back in and am looking to put an envy sports cat in but i dont want to put this in untill the problem is fixed
as if it breaks the cat again im £300 out of pocket
i heard of a simalar problem on an avensis where the first lamdor sensor had broke meaning the ECU wasnt gettin the required information
wondered if this could have happened due to the centre pipe being removed and cause the engine to overfuel and ruin the cat?
any input is much appriciated cause i really wanna get rid of this once and for all
had the lamdors out the other day but was no good as you cant tell if there broke from looking at them there just pretty black
if it is overfueling how much am i looking at for toyota to put it right?
if theres anymore info needed jst ask ill get it edited ASAP
thanks in advance alex
you could do a resistence check across the lamba sensors to see whether they are within specs that would tell you if the car was over fuelling
u will need to get the specs for your car then follow the wire from the sensor up to the plug
then unplug it and take a resistence check from the plug terminals (you will need a multi meter to do it)
well the cat was completely wreaked so i took it out as it wasnt working anymore and had my car decat'd as there are obvious performance benifits from it
its besides the point anyways as im trying to solve the issue with my car as im at the end of my teather with it
Well, if you're at the end of your tether, take it to a GOOD mechanic and get them to have a look at it.
Before that though... Put car back to standard with new lamda sensors as if they are totally black then they are shagged. Make sure all connetions are good (electrical and mechanical) fit a new air filter element, change the oil for good stuff, run some fuel-system cleaner through the tank when you next fill up, re-set ecu completly (remove the connection to it) then give car a good run for 100 miles, yes you're using your fuel and going nowhere, but what you're doing is refreshing the whole system.
Then, if its still knackered, get it to a mechanic. But please, do all that stuff, because from what you've said all that you've done is ***** about with the exhaust.
seveer - cheers didnt no that they were shagged if they were black got 2 news ones on order will i need to change both or is it just the first one thats important, ill change the oil, airfilers an apexi n thats stayin on cause its unreal thanks for the advice
TVOR- the benifits are increased BHP, more high end power, change in the exhaust tone (all depending on the car) ive noticed a massive benifit from it just wanting to get this problem sorted so i can enjoy the car to the full extent
Usually 1st one that causes errors, but change them both to be sure. If ever you change a section of exhaust with them in its advisable to change the sensors at the same time as any knock or dirt that goes near them can damage them. They're a very sensitive bit of kit. They should last 70k miles though without a single hiccup. Although a Decat will shag the second one pretty sharpish!
!Removed! the bed lol both ave been in for 121k now so there guna be well shagged
yea the sports cats going in same time as the new sensors and if that doesnt fix it im really lost and skint and wont b able to drive it cause im not wreakin the new cat
ill ave to take it to toyota to have my faults cancelled wont i?
do faults stay on the ecu after the battery is disconnected for the 20min period?
Not usually, as people on here say to disconnect the Battery for 1/2 hour to remove any engine management errors and for the light to go off
ah i see hmmm
if i take my Battery off for like 10 seconds my error light goes off for 40 mins :S
so basically if i put 2 new lamdor sensors in and reset the ecu? that should put things back to normal
and
if not ill ave to get toyota to cancel the faults / sort the fueling out?
ah i see hmmm
if i take my battery off for like 10 seconds my error light goes off for 40 mins :S
and
Hi, although it is not likely in your case, the cat can also get bottom screwed! by constantly driving through high water or by parking in long grass, etc, when hot. These things tend to overheat it and shorten it's life by quite a degree! More noticable on dropped vehicles!! :unsure:
