Removal Of Radio Control Panal In Dash
doughal
Hi folks
I have pressed one of the buttons in too far and its jamed and need to get in behind it to free it.
Have an 01 e11 facelift corolla that is that all the radio/cd control is built into the dash
Was also thinking of putting in a better head unit to replace standard radio.
Can i remove it easily enough without breaking something
Thanks for any help :thumbsup:
Its simple really. I have a 98 corolla round lights. to remove the radio in mine there is a small vent panel under top unit slowly and carefully prise it out. when you get it off there should be two gold 10 bolts each side of the unit take them out and the unit should lift out.. there is 3 clips on the unit be careful not to break them while taking them off.. well thats the way i done it on mine i presume it will be fairly close. and if you want to fit a aftermarket head unit into it... you can get a radio holder out of a older 97to00 corolla it should fit straight in......good luck..
