Annoying Door Lights/clock Problem
Stevie-G
hi first post
my celica 1995 has developed a problem when i open any door incl boot the clock goes off, when all doors are closed the clock comes on again and resets to 1:00. this corresponds with me rewiring the aftermarket stereo which was double wired onto the ign feed (both +ve wires on ign feed) also the door warning lights on the edge of the doors have stopped working and the interior light also has stopped working, i traced a blown fuse under the bonnet for the stereo and double wired the stereo onto the permant live feed. I am happy with the stereo but now am a bit p1ss€d off as i even disconnected the neg on Battery :angry: . Pls help if you can.
check the !Removed! lighter bulb hasnt been joined into by some other wire , your problem lies somewhere within the wiring for the interior lights.
had a look at this link http://toyotaownersclub.com/forums/index.p...showtopic=26524
points me toward a wire as theres a hundred wires in the stereo space one might have got pinched or damaged ill have a look when im next up at me garage (car has no mot/tax)
