Front Wheel Bearings - Carina E
penfold31
:lol::lol: :D :( :unsure: ;)
i'm new to the world of Toyota - I just need some help with my Carina E saloon. Its MOT time, this poor soul has sweated buckets tryiong to get the car ready before the unexpected just happened - driver side wheel bearing had worn out - I need some help on this as I need to know if its an easy job to do - my local car spares place had said i needed a flange as well as a bearing kit - I'm none the wiser - is there anyone out there with any hints an tips ??
My car is a 4 door 2.0i Carina E with the 3SFE engine, non abs or aircon with power steering if that helps.
I'd be very grateful if anyone could also tell me if there any reliable garages in Smethwick, North West Birmingham who could help me if my hour of need.
Ta muchly
Grasshopper
Replacing wheel bearings is not really a DIY jobbie on the Carina E. A press is required. What I have done in the past is to buy a complete hub assembly from a breakers and swap it over. The job is then relatively straight forward.
The job itself is comprehensively covered in the Haynes manual. But unless you have a puller and ball-joint seperator tools available it is best left to experts.
The procedure for the 1.6 and 1.8 is simple but the 2.0 is somewhat harder. Unfortunately for you.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
