2.0 Vvti Petrol Engine
Michael Kent
I have now had two 2.0 VVti engines fail due to cylinder head bolt thread degeneration at 90k and 95k
I would like to hear from any member who has had similar problems or who has exceeded this mileage without any problems
HI ,
I have Avensis 2003,2 litre VVTi, 97k miles and so far it is ok.
Best
Wojciech
Hi Thanks for your reply when the head was removed one bolt was less tight than the rest which had caused the gasket to blow this has now happened in 2 engines
Would be interested to hear from you again should you have any problems
Again Many Thanks Michael
Had any problems with coolant levels?
If the engine overheats it can soften the cylinder head causing the bolts to slacken off.
Just seems odd that you'd have two engines that failed for the same reason.
hi - i have 1.8 vvt-i with 91k and the engine runs well
cheers/igor
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
