hi i need some help for my glanza. ive fitted an hks fcd to my car and it stil keeps on cutting out. and ive noticed the engine managment light flashes about 5 times then goes off what fault is this?? can anyone help ? :(
you got supporting mods to enable the car to run safe past fuel cut?
my fault i ad one of the wires connected to the wrong wire, ive done it now and its not cutting anymore! does anybody know which number it should be adjusted to (hks fcd) ive got it on number 3 now and it seems alrite im running about 14 - 15 psi.
  • 2 months later...
you want it on 8-9, my friend is running 15psi on setting 9, says it seems fine
