Tyre Pressure Hilux 2.4 Diesel Single Cab
jules askham
can anyone tell me the correct tyre pressures for my toyota hilux 2.4 diesel single cab 1993?
Anywhere between 28 to 32 psi, depending on what tyres you have and how much weight you regularly carry.
There should be a sticker on the drivers door frame with tyre pressures on it.
Also depends what your using it for off road / standard driving or towing. Off road you might want to drop to 15psi for serious mud, i normally run mine around 25psi which gives me a nice balance for road and offroad so i dont have to keep changing the pressure, if i know im not going off roading for a while i put them up to 28 - 30psi.
