Zorsts!
Ryan1985
as far as im concerned yes
think they are on the same floorpan?
:thumbsup:
it must be a bit differnet? Isn't the 5 door longer?
dunno :unsure:
like i say i thought they were the same but with more openings?
:unsure:
could be? But if i remember right the doors would be small or the boot would suffer?
The front doors are smaller to make room for the rears..... the exhaust should fit.
all is explained! I thought something had to give.
Thought the 5 door was slightly longer? :huh:
Cos back when i was getting my yaris i looked at the specs for the 3 and 5 door and remember reading that it was slightly longer than the 3 door in addition to what yaristpot said. So i'm fairly sure thats the case, but no idea on whether the zorst will fit though :unsure:
am pretty certain that the length between 3 and 5 doors is pretty miniscule if anything, so don't see any problems myself
Now for the technical bit!
Yaris overall length: 3640mm (T-Sport 3660 due to bumpers)
Axel length i.e. wheel to wheel from the centre: 2370mm
Width: 1660mm
So yes, the exhaust will fit. As stated earlier, the doors are smaller on the 5 door. :thumbsup:
