M.o.t Help
Merve85
Hi i've got my m.o.t due soon and I have had a friend of mine look at my car.
So far I need a pair of front discs, a rear bearing, on the passenger side, and the handbrake travels when you put it on a few cm.
Does anyone know where I can cheap disc and a bearing.
And does anyone know if I need a new handbrake pad? Only thing is I cant find one anywhere so would it just need tighting up?
Thanks Merve
this guy is a god send i ordered a set of rear disc's and pads etc and he didn't have the disc's in stock, sent me the rest of my order and got his supplyer to send me the disc's direct, they arrived before the parts from him.
you can adjust the handbrake
there is a cog inside the hole at the bottom of this picture in the middle of the disc, tighten it as far as possible with out over tightening it then it should be approx. 8 turns to the loosen IIRC check a chiltons manual to be sure or the BGB
