Bulb Replacement In Dials
Aamir2892
Hi. Toyota Corolla GS 2.0D 1997
Could any one tell me on how i can get to the bulb in the dials as the one in my car has burnt out and i wanted to replace it but carnt get to it. The bulb is the one in the temperture needle area where it shows the tempreture of the engine. The bulb is for lighting up the display when you turn on the lights.
Would be very gratefull if someone could tell me how. :help:
in the dial surrond ypu'll find two philips heads screws, they need to com out then you can 'convince' the dial surrond out. there are then 3 philips head screws holding the actual dials in place, on at the top two either side at the bottom, once these are out you can coax out the dial a little way just enough to change the bulbs (it helps to disconnect the speedo cable) i'll post some pics up for you later ;)
Cheers thanks i managed to get the bulb out!!! Cheers for your help
