Dull Cockpit
vmail
hi, what you switch on the lights the cockpit(where the speedo is) goes dull and I have to press a button to make it go bright again, is there a way to make it bright all the time
It is so you don’t get glare when it is dark, the display can be too bright at night hence the display going dim when you put your lights on.
When I put my lights on before its dark I tend to press the button to make the display the day time brightness.
I believe this is a default setting, just press the display button till your happy with the brightness. :D
