Airbag Reset
maverick121
th airbag light has come on on my girlfiends yaris can it be reset
searched the forums but cant find a answer
poosibly disconnect the Battery for a while but will this lose the radio code does it have a code ? it is a 1.0 gls 2001
thanks
If the airbag light has come on then it means there is something wrong and needs to be checked before the light/codes are cleared!
It may just be a poor connection somewhere, a diag check at a dealership shouldnt be much.
Mart
could be a seatbelt at fault mate , they have pretensioners built in , toyota should check it for free cos if an airbag deploys whilst driving it costs toyota alot of money ,trust me, alot of money , i dont make airbag modules any more for toyota so its not 1 of mine. ;)
Check under the front seats to make sure the electrical connections haven’t come apart.
Putting anything under the front seats could have disconnected them. You will see a wire/cable under there.
hi thanks for the swift replies
she is trading the car in next week so was hoping it was just needing resetting
if you do that and the new owner had a problem - you'll find yourself in court!
poosibly disconnect the battery for a while but will this lose the radio code does it have a code ? it is a 1.0 gls 2001
thanks
Get it checked, just for safety. (How guilty would you feel if it went off in the new owners face).
The radio, if standard, will not hve a code. They were a Yaris only system, making them unlikely to be stolen.
