Developed A Squeek
chenks
a squeek has developed from one of the front wheels whenever i turn the steering to the left. it only makes a noise when steering is turned slightly to the left, no noise on straight ahead or on right turn or even on full lock left... only on slight left turn.
any ideas what this might be ? at first i thought maybe a wheel bearing, but that should be more of a grinding noise rather than a squeek ?
Might be the brakes rubbing a bit. Or perhaps the anti roll bushes, these are crap on a Yaris (See forum)
hmm... it doesn't sound like brakes rubbing, it aint that kinda squeek.
the squeek is quite limited as to when it happens. with the steering wheel straight ahead, if i move it like 1 or 2 clock positions to the left it will squeek, move it further on left and the squeek will stop.
I think i have something similar, friday night got a squeacking and grinding noise coming form the back left and front left, goes away when i ttap the brake - i think one of the brakes is slightly sticking, needs replaced this tuesday coming
