How Wide Rims For Rolla?
emsii
Does anybody know how wide rims you could fit to rolla?
I only need facts, not guesses. :)
I have atm 17x7 Toora's with 205/50 tyres, et35 and lowered with tte springs.
Im going to get 19" but don't know how wide they could be.
19x8,5, with 215/35 tyres..?
I would 1st start with the tyres size...
215/45x17 = TTE Compressor standard = Rolling Radius of 312.65mm
The closest tyre size in 19" I can find at the moment is...
225/35x19 = Rolling Radius of 320.05mm
Thats a difference of 2.37% larger.
Wheels........
A 225/35x19 tyre will fit on rims between 7.5J and 9J
The offset for the Corolla should be et35 - et45.. normally the wider you go in tyres the higher you go in offset to help prevent rubbing.
Going by the info above I would be looking into getting 225/35x19's on 7.5Jx19" (or maybe 8J)rims with an offset of et40 - 42.
Don't take what I have posted as FACT.. check the details with your wheel supplier before ordering.. that way if you get problems you may have some redress on the seller.
Thanks from the answer :)
I think that et could be 30 or less in the back. I have atm that et35 and it could be a little bit more outside, uknow?
It would be cool if the tyre is "stretched" on the wheel. That's why i would go for 8,5" wheels with 215/35 tyres ;)
Rolla has so flat sideline, that it would be also nice if the wheel is a bit outside.
But i probably have to ask from that local wheel supplier as you said and perhaps test different wheels for my rolla :)
