Hi today i visited Mr T as i found some rust coming out just above the windscreen and rear left light cluster cracked from the inside ! Now Mr T excepted straight away to change me the rear light and spray me the car roof but im not so sure of it as the windscreen need to be taken out! What would you guys do in the sitiuation? stick up with a tiny bit of rust or go through with the job? +They will keep the car for a week to carry out the job!
Get the job done properly and get them to allow you to view the stage by stage progress of their work.
Your car still is under warranty, so have them fix it.
You should be able to get a courtesy car whilst your car is in for repair
RUST?????
In TWO places?????
I would be keeping an eye on the rest of the car. I would be concerned if there is rust already on a new car.
Very unusual :(
A "tiny bit of rust" left untreated today in a "large amount of rust" after a year or so. You really need to get that sorted
hi guys tomorrow the car goes to Mr T ! I know the job has to be done my only problem is that the job is not carried out at the toyota service garage but at at private garage (sprayer) thats my only and real concern! as for rust on a new car as from i heard mine is either the first aygo with rust nor the last one! but we will see after the job is done! see you guys
