'03 Corolla
Carrera_C
I've got to change the light cluster on the rear of my Corolla. Anyone ever done it before? How's it done? How easy is it?
T.I.A
Chris.
T.I.A
Chris.
hi, there is 3 nuts on the back of the light cluster, cant remember the size? 10 or 12 mm. one is quite tricky to reach, be carefull not to drop it into the bodywork when removing. i used a ring spanner and a socket set. :thumbsup:
yeah i imported some from czech republic, there are 3 main bolts to undo, then the whole light comes out, swap the bulbs, connect the batch of wires back together and put them back in, on ur way!
