Defi Din Gauges
rallymad
XMAS is on the way and my better half has asked me what i want.
thinking defi din gauges would be nice if i get these what will i need to get them running on my 4?
i dont have any gauges in it at the moment so what will i need to run two temp gauges and the boost gauge??
Does anyone have these in there 4 or pics of one fitted.
Thank Paul.
You will need:
The DIN gauge
A water temp sensor adaptor for the rad hose (32mm)
A oil sandwich plate that fits in between the oil filter and the block. Needs to have 2 1/8pt fixings to accept the sensors.
You will need:
The DIN gauge
Thanks for the info they really look the job have to get them now . they really fit in well is that a boot controller where the clock is normally what type is it thinking of getting one going all out on the 4 for the new year.
I have looked at them on NENGUN PERFORMANCE seem fairly well priced.
Thanks again, Paul
It looks like a Greddy Profec B, Had one on my GT4, Very Good Boost Controller.
Fitting is simple enough, all the sensors are included so just plug into the back of the unit and then screw the sensor into the sandwich plate/rad hose adaptor.
I bought mine from Nengun as they were cheapest at the time, and yes it is a Profec B Spec II, does the job well as well as being nice and subtle :)
Or you could go for the bling that is the AVC-R, good controllers and cheap from the states atm with the current fall in the dollar
