Roadster Radiator Drain Tap
bgorman
Does anyone out there know of an easy way to get at the rad drain tap on the roadster ?
The block drain is dead easy (there`s even a little spout on it ), as are the two flow & return pipes under the front.
I can just about see the tap if I look down under the plastic under - bonnet cover on the nearside, but how can I get to it without removing acre`s of plastic covers. Or am I missing the obvious?
Ta, Bob
