Sorry to annoy anyone - but I'm in a bind. My headlight blew on my 1993 paseo, and I can't figure out how to change it. Basically all I've been able to do is open the hood. I have no idea where to go from here. (FYI - I did RTFM, and the manual said to detach the connector and remove the rubber cover, but it doesn't say how to get the headlight shield off first. Unless, of course, the shield does not come off, in which case I'm a dolt.) Anyway - if anyone can attempt to explain it, I'd appreciate it.
jimiih
93 Paseo Owner
when u remove the connector for the headlight, move the rubber donut. after there a metal hook thing, follow that metal hook to your left there should be a small bump. pull back and up which should open. move that out of the way and the h4 bulb comes out. now to put back is the same way but make sure the blub tabs line up, and go backward.
