:huh: Hello has anybody any idea where the thermostat on the 3litre turbodiesel hiace is? its on an m plate :rolleyes:
follow the top radiator hose down , it'll lead you right to it.
Or the bottom hose. ;)
:o Its underneath on the bottom hose so its a bigger job than normal. It looks like a lot of gubbins to remove first so I will post the results :rolleyes:
  • 2 months later...
:o It was a monster job compared to other engines! ,its on the side under the drivers seat and you need access from top and bottom. Even with a ramp it took me two hours but I am not a mechanic.
